bob85 said:
you do see differences between the two, granted it aint all in the 10k's favour,
what about a 10k vs astroplane test with the antenna tips at the same height and the astro on a pole insulated from the support mast 8-9 feet below the hoop as stated in the patent for best takeoff angle ????
that would put the tip about level with the 10k
Bob, I would really like to do as you suggest, but I'm not up to it right now. I'm still recovering from knee surgery and don't feel comfortable working at heights since my surgery. I developed a bit of vertigo and I’m not getting any better fast. I have the poles up and the antennas, but I’m just not up to it anymore.
Could you answer a few questions or anybody add comments?
In your post above, you noted that the patent indicates that the mast #14 needs to be 8-9 feet below the bottom hoop. This suggests this is the optimum length possible for best TOA and it is true that the patent states those words. However, I sense you also feel that 8-9 feet is the only length for the mast period, in order for the antenna to show the optimum TOA. In the same vain you speak about insulating the mast at this 8’ point from any supporting structure in order to maintain this optimum length if you plan to elevate the antenna.
Do I understand you correctly?
I read the patent differently and I don’t think this is what the patent states or implies. I read it a though this length of 8-9 feet is just the minimum that should be used or else the TOA will rise up. See section 3 lines 42-55. IMO, when Avanti scaled down the antenna to 2 meters as noted in sections 4 lines 46-75, and section 5 lines 1-14, they verified that making element #14 shorter than 1/4 wavelength would tend to raise the TOA, but said nothing definitive about making it longer. So I guess this does raise a question. In section 5 lines 11-14 there is mentioned a 20-foot mast to be used with this antenna as designed. Your idea suggests a mast length of about 16-feet, while Avanti suggests in the patent using a 20-foot mast for #14. When I read it, I am not persuaded that 20-feet is the best way to go here either, because a 20-foot mast does not provide for the maximum tip height under FCC, Part 95 rules, which provides for an omni directional antenna and supporting structure not to exceed 60 feet above ground level. Under this rule an AP could be supported on a 56-foot high mast and a typical half wavelength ground plane would need to be on a 42-foot mast.
In section 6 lines 9-14 it is suggested that the use of a 4 foot top loaded element #46 including 4 feet of capacitance cap adds bandwidth. Thus for me, this suggest that if this element were replaced instead with a full 1/4 wavelength monopole it would show some improvement in efficiency for the antenna as the bandwidth was reduced somewhat. Sounds like to me that adding a cap hat was a reasonable compromise, allowing the antenna to be elevated an additional 4 feet higher within the FCC limitations and providing added bandwidth in the CB band. I think most CB operators would prefer a broader bandwidth, but within reason I believe antennas, operated at resonance, will typically show a somewhat better signal as the bandwidth were made more narrow as apposed to made very broad. Maybe the idea of full 1/4 wavelength monopole on top of an AP, as use with the AP Beam, would perform better in the stand-alone version too. And, that if one really wanted to raise the TOA and elevate the antenna far above the earth, then decreasing the length of #47 to less than 1/8 wavelength and increasing the length of wire elements #48 and #50 in order to maintain an electrical 1/4 wavelength for element #46 on top would be the way to go in order to raise the TOA a bit. Additionally it is also noted in the patent that the flare of elements #16 and #18 has an affect on impedance, as well as an affect on TOA. See section 5 lines 56-61 for explanation.
The clincher for my opinions here are in section 6 lines 14-25, where the term
at least on line 16, is used to describe the length of mast #14 below the bottom hoop, and the words
are omitted on line 23, are used to discuss the consequences of removing the capacitance hat radials at the top of #47 and make the top element #46 longer at a full 1/4 wavelength.
I remember somebody wanted to check out the TOA somehow using a modified AP, but cannot recall who it was and if they did that project. I have been off the forum for about 6 months doing my 50th reunion events.
Bob, do you know anyone that can modeled the AP and maybe check out these ideas?
