C
Crazylegs74
Guest
I'm getting a Cobra 29 installed in my '84 Silverado, and I would like to mount the antenna to the front corner of the box. Is this OK, or will the proximity to the cab cause a lot of interference?
I am limited to antenna no more than three feet long, and even then I will have to get fold-down type brackets. Would it be better to run a single or double antenna?
I was thinking of going with double. But then I found out that they're supposed to be 9 feet apart, and the distance across my bed is only 6 feet. How big of a problem is this? Would it be better to only use one?
Any help you can give me would be greatly appreciated.
Crazylegs74
Crazylegs74
