I read a lot of post and now are really confused. I have the 4' Firestick from years ago. I installed it on my jeep using the coax from my 4' marine Antenna. they are both top loaded there is no ground on the marine antenna base. cheap molded thing. I cut off a length of coax @ 12" that was soldered center wire to ground on the dead end and the center wire soldered with the other. so I cut it off. I hooked up my MidLand international swr meter it has a 2 position switch. FWD and REF and a knob to Set the needle I think I used it right by setting it with ref and reading my SWR with the FWD well it is in the middle of the RED. not good. I can shorten my cable to help it is still stock length. I read about the 18' myth. and don't mind cutting the coax.. I could cut about 2' and see if this brings it at least out of the Red. or should I try the marine Antenna first to see if there is a differance in the SWR. I know with the Marine ant the lake is the Ground plane.. So I am asking what should I do. ?? Thanks for any Help..
