Hi
I think I made the mistake of buying a Tram 1499.
no ground plane antenna. It picks up a signal good, but it don't send more then static.
on my base radio. I mounted it outside on the top of my garage, about 40' up.
I used 100' of Rg8u. [suggested by the manufacturer]
I got a pretty good antenna match 1.5.
I have a old Pearce-Simpson Jaguar 40B. It shows 3 watts
dead key on meter but no swing at all when I try to modulate. I got static on the
receiving radio but no voice. Maybe bad finals ??
I tried an old Midland 77-838 mobile unit, good match , 2 watts dead key,no swing
I got out about 2 miles with that with good sound on receiving radio.
I ordered a small RM KL203P 100/200w Linear Amplifier at the same time I ordered the Tram but it hasn't come in yet. I hope that will help. I seen people on you tube using a mobile 102" whip as a base antenna. I'm thinking that might work for me. I have a metal roof on the garage and I could use the metal roof for a ground plane for the 102" whip.
But I don't know how I could adjust the swr on the steel whip.
I want to put up an IMAX or A99 on the garage
but I didn't know if they would work without their ground plan kit.
And I think my neighbors will give me a hard time if I have to use
a bigger antenna with the ground plane kit. But I guess if I am going to get back into the cb world. My neighbors are going to have to get use to looking a big antenna.
mounted on the roof of my garage.
Any suggestions would be appreciated.
Thanks !! 73's
Thanks !! 73's
