Currently I'm running a Sirio Gain master ground plane. I'm building a 40 foot crank up tilt tower mast for a set of 4 element Gizmotchys. My question is I'd also like to put to ground plane on the tower also but I'm not sure where or how it should be mounted in relation to the beams. Above it? Beside it, as to not affect the performance of the beam? If I put it above the beam will the pole affect the beam in performance or swr. Any help or suggestions would be greatly appreciated. I'll post a couple pics with so you have a good idea of the tower I'm building. Just a couple pics I got offline that gave me the idea. Thanks
