If you have a mobile magmount and set it up perfectly on an SUV and than switch it to another SUVs do you think it has to be setup again. I guess with roofs being different, moon roofs etc. it probably has to be redone. Whats your thought? Ron
What is not always understood is that the vertical antenna is just half of the antenna system. The other half is the vehicle body.
Both halves radiate.
You would not expect a dipole antenna to have the same characteristics if you cut (or lengthened) one side. Ditto with changing vehicles!
Do both halfs of a dipole radiate? Yes, Do both 'halfs' of a vertical antenna radiate? Yes. All antennas have 'two halfs'. Both radiate. Only one 'half' of an antenna can't radiate anything, it always takes two 'poles' or current doesn't flow. No current moving means no radiation. Sometimes it's a real 'trick' to figure out where that 'other half' is, but it's always there...
This does not mean it radiates.
A properly constructed ground plane will be set up as such that any radiation will be exactly out of phase with the radiation on the far side of it, and thus any radiation would cancel.
