Well I almost got it done.. Someone said use a saw blade to support it.. Now I see why.. Here are pics of the install.. hope it doesnt leak.. Will post swr and results when its all done.. comments?
Looks like you have got it reinforced very well.
the biggest deal is to have a good RF ground.
usually this is accomplished by sanding away the paint around the mounting hole so that the ground part of the mount makes a good shiny metal to metal contact.
you have used a mount that i do not recognize. is that actually a roof mount?
or some other type that you retro-fitted?
it looks like the mount is grounded well to the saw blade, but how well is the saw blade grounded to the actual roof metal?
the paint should have been sanded away here so that the saw blade made a good shiny metal to shiny metal contact.
other than that, it looks well supported.
even if you dont want to use it while driving, go get yourself a 102" whip to carry around in the car with you for when you want to sit still and DX.
you will like the way it works.
You should have gone thru that support brace a few inches over from where you drilled.
Couldn't agree more.
Probably not at all.
sawblades are ideal for robbing bank safe's,but don't cut it as an antenna ground plane.
i'd hate to see the haircut you get should you be unfortunate enough to crash and that saw blade came flying loose,dearie me.
Good luck drilling through that saw blade.
