rebuttal........
a post i saw recently in another forum sums it up best........
"A 1/4 wave antenna has no gain, in fact, it has a negative gain"
Incorrect. It has 0.3 dBi, where the "standard" is the "i", and the "i" stands for isotropic. If you treated your antenna as a point inside a sphere, the "i" means equal illumination flux at all points on the inside of the sphere. the "gain" comes from focusing this flux to less than a perfect 3 dimensional sphere. If all the power was radiated perfectly spherically, and all this power were put into half the sphere, the flux density would be double at any point in the half sphere versus what it was for the whole sphere. This is all antenna gain is. If a "d" were used instead of an "i", then we would have a "standard" of a dipole, which would have been set in reference to the "i", where in all considerations the "i" is the true starting point of reference no matter how you were looking at the picture. The diameter of the sphere matters not, as the total flux density would merely be spread out over a greater area. Many people mistake the inverse square law as meaning the signal gets weaker with distance, which is incorrect. The total photon flux never changes, it just gets spread out to where any certain cross sectional area sees a reduced concentration of flux. The only exception to this would be in the case of absorption of energy by something in the path of the EM wave. Since gain is referenced to isotropic, it is in fact wrong to conclude that the 1/4 wave has negative gain, since isotropic implies 0 dB, and the antenna would have to be below zero, which a quarter wave is not.
but the antennas which are the subject of this article do exhibit negative gain figures below 0.0db. when compared to their full-size 1/4 wave counterparts.
and let's not forget the credits........
Posted: Jun 24 2004, 10:48 PM
By: AB7IF, Russell Clift
in addition, since mr2020 is studying something called "antenna therory" that i am unfamiliar with, i'll refrain at this time from any comments except to say that i would appreciate the opportunity to discuss anything he views as "double talk" in the associated article. until any such time that aberrations or inaccuracies are evidenced the article will remain as-is.
contrary to any presumption on his part, the information in this article was obtained through an accumulated effort involving theory, practical experience and constant application, references and notes of those who have gone before and literally thousands of hours of field use and testing. but then it is so typical of most of those in this area to discount someone elses hard work with little more evidence than mere generalizations and tired cliches.
i'm used to it.
</p>Edited by: <A HREF=http://p067.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=freecell>freecell</A> at: 7/7/04 11:25 am
