Click here to find out how to win free radios from Retevis!
I have found that usually turning down the bias a lot lower then where the factory has it adjusted will make it last in there. I think they just have it turned way too hot to last. I havent seen anything that is easy to do to replace it with. You can use the ERF2030, but you have to bend the legs because the pinout is not the same, and it doesnt gain you anything. I would say stick with the stock part.
I ended up turning one down to about 200 or 300 ma for a customer, and it seems to work just fine. I've often wondered if the 1.3A factory recommendation was a typo, and its supposed to be 130ma....
I think mine went out once because of being set to high but the other times it was result of static. Both the times it went out as result of static I was not home to disconect the antenna when a storm rolled in and when I got home the RD16HHF1 was fried.
