Just curious if this arrangment has been "coined" or named before?
[photo=medium]4313[/photo].
Thank You
Thank You
The Cobra 148 GTL/DX, same as the SuperStar 360FM MkII . . .Scratch the last post I made, I am more concerned with knowing what Uniden radio RCI cloned when they made the ept3600 series boards?
IIRC, the current requirements for the chassis for dropping in a MRF477 will exceed the specs for the mode selector and a few other critical points in the radio circuit. Perhaps not such a good idea.I think I found the "hidden gem" I was looking for: The Jackson, with an MRF477 dual finals are not needed, I have just read here that the Jackson uses low level modulation (second to last paragraph). I wonder how I can verify this, and or compare the schematic to an ept3600 to clone the setup for an experiment i'm working on.
Need an old MRF477, I have an MRF646 for UHF any traders out there?
