I have a 4 year old 55" Vizio TV model E55U-D0 with issues.
Was watching TV one night via Firestick and suddenly screen started turning from movie to lines and colors and audio cut out. (see all pics below)
Went around the boards pushing on them to see if it was a cold solder joint or something but no dice.
When I turned it off and back on I do have sound. So I decided to try replacing T-Con board.
I replaced T-Con board but that had zero effect.
There are only three boards so wondering if I should just continue on and replace the other two boards?
master board - $55.00
power supply board - $25.96
A new cheap brand TCL TV is $299.99 so not sure if I should keep going on the repairs or just junk it. I hate to be a throw away guy if it's just one of the boards.
I emailed a TV repair guy and he said - looks like screen has issue because of the color in the lower left
BUT the color comes and goes and the vertical lines change in intensity or disappear and then reappear. I have ZERO experience with screens though but seems strange the way it went out. Researching online other people with screen issues seem to get one spot or a black screen - not a bunch of lines.
Anyone have any ideas? I'm wondering if maybe it's not getting enough voltage and something is wrong with the power supply or something on the main board is wacky.
