Anyone familiar with the Midland 77-155 40 channel radio?
Turbo T
Certified CB Rambo
Feb 2, 2011
963
142
53
I have one of these radios. If you disconnect the power source in the rear, the radio resets itself to channel 9. As long as you don't disconnect power going to the radio it will stay on whatever channel you put it on.
Turning off the radio does not cause it to lose it's memory either, just if you disconnect power.
Since I use this radio to monitor highway reports, i'd like to make it to reset to channel 19 by default.
I was wondering if anyone has any ifo on how this is done? CB tricks doesn't give any info.
Thanks in advance.
