As title just wondered if any one has doubled up or try a different number of full size ground radials on a 5/8 vertical and see any difference in a model or real life????
I know the big mack had 6
this probably deserves its own threadI may make a 5/8 wave wire ant with some leftover coax. Anything I should be aware of? I don't have an analyzer to check resonance and reactance.
thanks for that Marconi ....have you tried only 3 to see what happens .
Altho i have come up with a very good neat idea to mont 4 radels but it not work with 3......but it will be interesting to know if their is no disadvantage with only 3
Dave, 3 should be just about as good as 4, assuming maybe you get the there evenly spaced around the feed point...which might not be as easy as it looks.
Did you understand what the models indicated? Did you notice the 8 showed the gain was a bit less, and did that confuse you?
Did you notice the currents on the mast for these models? This has an effect of making the gain look better sometimes, because the current on the mast is strong. The model with 8 probably decouples the mast from the radiator a bit better, less currents flowing on the mast, and that can make the model more accurate and seem to show less gain. However the model with 4 radials, was the opposite and thus there is more current on the mast, and that skews the pattern and the gain some...which is not always best.
Then the question arises, how do we ever know how this stuff works if we don't consider modeling? Even being really careful with real world observations can be misleading.
What did you experience using 3 radials only? What I said above may relate somehow to what you experienced using only 3 radials.
Does efficiency play into any of the modelling?
AM broadcast towers typically have 120 radials beneath them. If it were better to stick with just four I'm sure they would not go through the added effort and expense.
