I've about had it with the static around my QTH with static. Ive had the power company out here 3 or 4 times. They've replaced two transformers and several insulators. I've even had the guy on the phone with me as he disconnected the power to my neighbors homes to see if it helped. I was sooo impressed with that but never the less the static remains. It was in the 7-9 s-unit range but with his help its in the 2-4 s-unit range now. I started out with an imax at 31.6 per marconi's study basically because I had it on a push up pole at the end of the house. Now I have a V5000 on a crank up tower about 67' to the bottom of the antenna and the static is still here. I am used to dead quiet and feel thats the way it should be but I bought this house and i'm in it for the duration. Ive run a ground wire from the antenna itself all the way to the ground and i've driven down a 9' copper pipe and grounded the antenna. My hands are in the air folks.. Ive got a good collection of radios here and most all of them read about the same thing.
I was wondering if anyone had tried this unit and if it works...? I guess it would go between my radio and my amplifier? looks like that should work..? one would think.. If anyone has tried it i'd like some input as to whether its hard earned $$$ well spent...
Thanks
CB-112 :headbang:headbang:headbang:headbang:headbang:headbang
Thanks
