Anytone AT-5555N II (version 2). AM modulation swing and or SSB safe power output adjustment
Is this chart for the AT5555n2
No. It says right at the top of the chart....
Anytone AT-5555N Original Service Menu Settings (First Radio V2)
So it is for the 5555N, which is an entirely different radio than the 5555N2.
There is zero need to go into the service menu on these radios.
There are parameters that can only be adjusted with the right service tools. If you change the parameter and don't have a freq generator for example, you CANNOT change it back to how it was !
I have the 5555N2 and it works 100% OK right out of the box. There is no need to adjust anything that can't already be adjusted in the regular menu.
Reactions: Pez
I know I'm an idiot but do you have the numbers from 1 to 59 off your new one so I can go buy it for reference
I think you may have already screwed the pooch on that one. They aren't all the same for every radio.
That's why everyone cautions on entering that service menu without being first prepared with the right knowledge.
Reactions: Pez
There's the guy on here said they did a couple of them and they compared to them and they were pretty much identical on the settings he's got a couple downloads on here but I can't open them I don't know why
now I need some very important info .I have my AT-500M11 CB radio. I need to boost modulation just like the AT-500M and lower dead key for my KL503 box can any one help me, can't seem to be able to find service menue like the AT-500M
I found service menu but don't know code for Modulation, I found power settings and turned dead key down but only have about 4 watts swing
#52 (AM RF Gain) and got it set the way I like so strong signals do not overload my front end and i still hear far off stations without all the hiss and heterodyne. Shout out to Panic Attack for his input on this site about the Service Menu and 352 for his assistance with the Menu settings.
Great article, thanks. What value did you settle on for #52 on your radio ? After making the change did you discontinue use of the RxNR ?
hope the newer 5555 is better than my 6666 .i just cant get accustomed to it or its control layout.
think i might sell it add few $$$ n buy another stryker sr 955 hp
Hi ALL,
Hank here and I am "returning" to the CB world in retirement from first hitting the airwaves in early 70's. I have found - internet search is great - the following list of what service adjustment "numbers" correspond to function..
I found the service mode entry procedure, Thank you kc4eoe, and with a good scope and other gear, am going to "look" first at my new AT 5555N II coming in today. The following is submitted, maybe duplicate from an earlier post, but, here it is again. Any comments as to the confirmation of applicability to the AT 5555N II model will be appreciated, BEFORE I may tune.... The values are from an unknown source radio, but, may give some idea to what you may see....
(from kc4eoe)
To Enter Menu – Hold Menu and Mode and
power up radio, then quickly press
Mode,DW,RB,NB, Scan, Mem, and Emg
Ch 1 – Ch01
Ch 2 – Ch02
Ch 3 – Ch03
Ch 4 – VCO FRQ = 51 (50)
Ch 5 – BFO FRQ = 50
Ch 6 – TX – IQ1 = 140
Ch 7 – TX – IQ2 = 168
Ch 8 – TX – IQ3 = 183
Ch 9 – FMPOWH = 158
Ch 10 – FMPOWL = 65
Ch 11 – FMRSSI = 2998
Ch 12 – FM MOD = 250
Ch 13 – FMTONE = 65350
Ch 14 – CTC = 52
Ch 15 – DCS = 42
Ch 16 – AMPOWH = 150 (138)
Ch 17 – AMPOWL = 94
Ch 18 – AMRSSI = 1522
Ch 19 – AMMODL = 164
Ch 20 – AMMODH = 176
Ch 21 – AMTONE = 65226
Ch 22 -- USB UL POWH = 231 (170)
Ch 23 – USB UL POWL = 89
Ch 24 – USB PA = 05
Ch 25 – LSB PA = 05
Ch 26 – USBBPWL = 109
Ch 27 – USBBPWH = 211
Ch 28 – USB BPFUSB = 45
Ch 29 – LSB BPFLSB = 92
Ch 30 – USBTON = 65213
Ch 31 – LSBTON = 65218
Ch 32 – AM RX BPF = 0000 Sounds
Ch 33 – AM TX BPF = 0000 (255) better at 0000
Ch 34 – USB UL SQL = 265
Ch 35 – USB UL SQH = 3757
Ch 36 – FM AF SQH = 3854
Ch 37 – FM AF SQL = 596
Ch 38 – FM ASQ H = 113
Ch 39 – FM ASQ L = 453
Ch 40 – FM AF RS1 = 609
Ch 41 – FM AF RS3 = 2376
Ch 42 – FM AF RS5 = 2906
Ch 43 – FM AF RS 7 = 3152
Ch 44 – FM AF RS9 = 3474
Ch 45 – FM AF RS12 = 3854
Ch 46 – USB UL RS1 = 263 (2218)
Ch 47 – USB UL RS3 = 1379 (2398)
Ch 48 – USB UL RS5 = 2736
Ch 49 – USB UL RS7 = 3079
Ch 50 – USB UL RS9 = 3395
Ch 51 – USB UL RS12 = 3757
Ch 52 – AM RFG = 86
Ch 53 – AM SQTH = 02
Ch 54 – AM ASQTH = 04
Ch 55 – WX FRQ = 249
Ch 56 – WX 500 = 82
Ch 57 – WX SQ1 = 72
Ch 58 – AM V BAT = 102
Ch 59 -- AM VER100 = Nothing Happens with Key up.
Hope this info even if repeated, may help a newbie like myself, to get on the right track....
Hi just wondering how you got the ones to change with the big numbers as mine wont do it thanks
Reactions: Rwb
Hi ALL,
(from kc4eoe)
Ch 1 – Ch01
Ch 2 – Ch02
Ch 3 – Ch03
Ch 5 – BFO FRQ = 50
Ch 9 – FMPOWH = 158
Ch 10 – FMPOWL = 65
Ch 14 – CTC = 52
Ch 15 – DCS = 42
Ch 17 – AMPOWL = 94
Ch 24 – USB PA = 05
Ch 25 – LSB PA = 05
Ch 52 – AM RFG = 86
Ch 56 – WX 500 = 82
Ch 57 – WX SQ1 = 72
Just wondering how do u change some of these settings as mine only lets u change some of them and some won't change to the numbers u want thanks
The list is for a different radio. Some of the settings need external equipment to generate the value. If you select the parameter without the corresponding signal going into the radio, the value will be zero and your radio will become a door stop.
Reactions: Woody-202 and Pez
  • @ kingmudduck:
    So I have a cobra 138xlr and the meter dose not work... It dose not key up and signal dose not work.... It is not stuck it the meter moves freely. now wires are resoldered on both ends...So now that do I look at. Could it be a diode or a transistor?
    Greg T has joined the room.
    Greg T has left the room.
