Anytone At-6666 Pro
I just received my 6666-pro straight from china, just trying to get 11 meters going on this with no luck. I see there are 3 2 pin jumpers and one 3 pin jumper, I suspect its one of these. Anyone convert there own?
Figured it out, jumper is for 15 meter...not needed here. I hope this turns out to be a decent radio, cheers!
Conversation started.
Reactions: TIN_CAN
It has already been said several times, moving the jumper is only useful to add the 15 meters (21MhZ). For the 11 meters you need to press a sequence of keys. It is perfectly explained on Youtube
I couldn't find a video for the new Pro version, are you sure that's the same power up sequence for the 11 meter mod?
The videos I've seen are for the older version.
I would like to know how to do it myself.
Post or Send me video link if you could.
Reactions: whiteastro
