Hi all,
I am wanting to build the old radio shack (Archer 21-901) 1/4 wave CB ground plane antenna.
As these were mass produced, aiming for exact measurements, allowing for minor construction errors should yield matching (near factory) results.
There is a link where it is almost completely described in detail by Stephen Dubin & others :
http://www.worldwidedx.com/threads/my-guess-is-its-an-antenna-specialists.168114/
but I do not know the diameter of the hair pin wire.
I am referring to it as beta match, forgive me if it is something else.
I have read:
All radiators are 104":
1/2" x 59", 3/8" x 44" , 1/8" wall
59+44 = 103"
(but they must overlap as they fit within each other)
(knowing the un-assembled lengths would be great)
I have read elsewhere the ground plane radiators should be 5% shorter, but not sure if thats true, or applicable due to the beta match.
104" x .05 = 5.2"
98.8" shorter, or 109.2" longer
Driven element has single drain hole
Driven element does not contain re-enforcing dowel
Driven element ?-inches above mounting baseplate due to mounting stud.
The beta match is 7.5" x 1.5" separation.
Attaches to underside of ground plane radial, and side of driven element
Hole for beta match attaches (?-inches) above base plate to driven element.
(7.5 - (1/2 /2) - 1/8) = 7-1/8" visual estimate
(beta meas.) - (1/2reflectDiam). - (mountPlate) =
?-inches of 1/2" material secured to base plate as radiator, 1"-???
Ground plane elements offset ?-inches tangent from centre of base : 1-1/4 to 1-1/2 ??? (guess)
I know if I bend radiators, I can forgo the beta match but modifying the original design is not where I am hoping this thread will go.
There was one on ebay I missed out on, and have not seen since or I would buy and share it in detail.
If anyone is willing to measure/confirm the fine details of this antenna, (or have ANY parts of a dead one they'd be willing to part with for examination purposes, please contact me). Or a whole unmodified unit.
Why not build a different one ?
I don't need a different one as I have a .64 wave.
(sorry, not for sale)
This is somewhat sentimental project as this was my first antenna as a kid.
I'm pretty sure I have the original manual from 1977.
Any help would be very much appreciated.
Doug.
I have read:
59+44 = 103"
104" x .05 = 5.2"
Doug.
