here is a good one,I run a v5/8 for an omni,my neighbor always ran an a99,my Maco is 44ft to the base his a99 is 34 ft to the base,the maco has always talked all over his a99 to several bases 50-60 miles away on ssb always 1-2 s-unit stronger,we put up the army stick which I believe is called an ABS 2100 and it talks right over the Maco no problem,he is running a ts 690 ,and I am running a ts 570s both running around a hundred watts,the Maco was built by the specs found on this forum and the match is perfect it was checked with 2 analyzers,the big stick has a match around 1.3-1.5,we have even swapped radios with the same results,the stick out talking the Maco,last night on 38lsb we were talking with the usuals and a station came in that was 100 plus miles away that heard the big stick but could not hear the Maco enough to make out what I was saying,I replaced an Imax with the Maco last fall and have been very pleased,it heard and out did the Imax no problem,maybe it is time to find an Army stick.
chris.s
chris.s
