Alright, it's been awhile since I was on here and am now finally finishing up the "flag pole antenna" for the CB radio. I have been pretty happy with it, I am receiving transmissions from other states (weird I know, but hey, it works) and transmission is pretty good at long ranges as well, but since it is a ground plane antenna, I would really like to add more radials. Now, my question is, if I was to make a junction board (k, pretty much a small board with a bolt and wing nut on it. a loop would be tied in the copper shield from the coax, the loop would go over the bolt on top of a washer, on the ends of the radials (closest to the mast) there would be the clamp on eyelets for electrical work, those would slide over the bolt, and then then wing nut would tighten down and make all radials contact fully. Anybody think this would work well?
Oh...here is the thread by the way...
http://www.worldwidedx.com/cb-anten...io-antenna-radials-question-2.html#post153643
