B
BOOTY MONSTER
Guest
i got a dude in the area with a couple of 50 amp and 60 amp audio authority power supplies used from circuit city for their car stereo display . are these good power supplies ? im thinking they should be but at the same time they are probaly at least several years old and may have been on constantly for that time . ill check the manufactures date on the info on the back to check though .
i can only find info on the 100 amp version .
Audio Authority® - Product Details: 978
but apparently its pdf manual applies to the 60 and 80 amp versions as well .
http://www.audioauthority.com/techdocs/978manual752417.pdf
apparently it uses 20 amp modules for upgrading and if one fails the others still work minus the power from the failed module .
im supposed to call him back tonite when hes home to get more info on the model number and designations on the P/S's he has .
what do you folks think ???????
