So i picked up a $9 Volt analog meter from ebay for a spot in my dash that was perfect for a meter and the diameter of the hole: (60mm). So here's my problem, The meter reads 12vdc when clearly my real voltage is 14.XX ( my Chevy truck has 6 gauges including voltage in the dash cluster) but i wanted to utilize the hole with a meter! Why is the meter reading constant 12v? I feel the meter is more of a dummy meter than an actual real reading meter. Do any of you know a place that sells a 60mm meter that is analog and isn't going to kill the bank?
Here's a picture of the meter ( I wired the DRL to the backed lit LED display to come on when DRL's or headlights are manually switched& its also wired to the dash dimmer).
Here's a picture:
Here's a picture:
