1:1 50 ohm in 50 ohm out, 1:2 100 ohm in 50 ohm out, 1:4 200 ohm in 50 ohm out, 1:6 300 ohm in 50 ohm out.What does, 1:1, 1:2, 1:4 etc on a balun mean?
It's not just about the feedline impedance - it's also about the antenna's impedance. An example is if you are using an antenna with an especially low impedance, a balun can greatly improve matching. For example, if you're using a Buddipole on 40 meters, the antenna's impedance could be pretty low, like 12 ohms or so (I'm just guessing here). Using a 4:1 balun brings the impedance seen by the transmitter much closer to the 50 ohm range.
What would a 1:1 do?
Sent from my Xoom using Tapatalk 2
