OK, I changed my setup around...and my RG8 from my antenna is about 6-inches too short to ideally mount my meter permanently inline. I'm running a 5-pill in this system.
I don't know coax or its connectors enough to know if a barrel connector is a proper/correct thing to do or if it is a considered a band aid that shouldn't be done. Should I just run another piece of coax, or could I safely/correctly get away with a barrel connector and a short piece of coax as an extension??
Thanks
Thanks
