Hy-Gain came out with the Super Colinear in 1962. It was a flop, because it broke off at the base, it was single point mount for the vertical element.
Then Hy-Gain came out with the CLR II. Mid 1960's I believe. It had a two point mount that would stand up to bad weather, but had a Mickey Mouse cheap bad impedance matching device on a circuit board, located in the bottom insulator. Any power would burn out the etched coil on a circuit board coil.
Then Hy-Gain came out with the Penetrator 500 around early 1970's. It was advertised to take 1500 watts.
In 1980 or so, Telex bought out Hy-Gain. The Super Penetrator 500 was then sold. It had a gold like anodized finish. But Telex cheapen the design of the orginal Penetrator. Hy-Gain Penetrator's have two 1/4" inch bolts attaching the ground radials, and the Telex has one 1/4" bolt. Same antenna, but the Telex antenna was not as beefey. Worked the same.
Hy-Gain came out with 3 each Penetrator 500 antennas.
1 the first one was 259 inches long for the 23 channel radios
2 & 3 where 256 3/8 inches long, for the 40 channel radios.
There was just vertical element length differences, for the longer lengths. You can tell it you have a old orginal 23 channel P500, the bottom vertical element is 1 1/4 inches in dia, but is 77 inches long, the other 40 channel ones where 71 inches long. You simply shorten a 259 inch P500 to 256 3/8 inches, if you want. The Ground Plane Radials and tuning wires stay the same.
Telex took over Hy-gain in 1979 or something like that. Telex P500 antennas have only one bolt holding the ground plane radials inside the mounting Clam Shell Bracket.
Telex is the one that made the Golded Penetrator 500, that had a cheap gold anaodized finish to it that would come off in a few years of use.
Yes all the P500 where called part number "Order 500"
Hy-Gain ran into problems with the tollerances of the Aluminum Tubing "Wall Thickness". Tubing .058 inches wall thickness did not always come .058, it get to be thicker not allowing the tubing to "Telescope" inside each other. So they came up with the Reduced Swaging the ends of the tubing, to allow the next smaller size to fit into the reduced swaged ends. This allowed the element to be strong and light, being resilant.
Most all the tubing used by Hy-Gain from what I can see was good material.
Jay
