The Imax 2k, I bought it new a few years ago I set the swr on it and used it on the 11m band....I set the swr on channel 20, 27.2050, and the swr was all good on the upper end of the band, because at the time I used to talk dx on 28, as well as the ssb channels from 36 up...and the swr was running a 1.1 or less with out running power on it, and with 2 amps I used to run the swr went up a little to a 1.3, never went any higher....
After I bought that 2995dx, I started using it on the 10m band, this is when I noticed the swr on the 10m band, and it was running a 1.5 or less from 28.305.00 through 28.500.00 ....
Over the years I owned his antenna, I have moved it couple times to a different location I taped the rings up so they didn't move any.....and even now with this FT 450d, the swr is the same on the 10m band, nothing has changed....
But have noticed as I have checked the swr on 12m band the swr has changed, guess this is due to the swr not been set for this part of the band...so after it warms up I plan on taking the Imax down and setting the swr on the bands I can use it on....
Just getting started in the HF radio stuff, and I do like to fool with antennas, more than anything else......I'm sure you guess already no this since I used to have a line setup here that some of you didn't think it worked...
