Click here to find out how to win free radios from Retevis!
You might want to consider adding a duplexer (tri-plexer?) in line to peel off the 220mHz which that HT can deliver at ~250MW and have some fun with a Hustler G-7 220mHz antenna on the 220 band.
Just don't get hooked or the next thing you know, you'll be spending $1300 on an ICOM IC-575H 220mHz all-mode!
I do find that most all of those on 220 simply want to have a good time chatting (no BS) and are part of the most well-kept secret of Amateur Radio.
the ar270B is a okay little antenna, it was my first one hooked up to a alinco DJ 580. i still use it today as my travelling antenna, hooked up on a telescoping painters pole and a bungee cord strapped to anything vertical that allows it to clear it works great. you will enjoy it
