Base CB Antenna Height?
Galaxy 959
275
57
38
Arkansas
I got a 50-60' nice tower gave to me. I only plan on using 40' of it for my Sirio Tornado 27. I've had people tell me just to put it at 36' at the first wave length. Whats your guys opinion on this? Should I go 36' or 40'. I might can get to 45'. My new coax coming in is 60' and I might not need the whole 20' extra to make it into the house. I've googled it and get just mixed results. Just want your guy opinion. Thanks!!
The higher the better.......,and someday you may put a bean on there with the omi. over that, and maybe a dipole off the side....Don't for get to put an arm or two and pulleys as well with some good line on the pulleys so you can put things up, and down. Maybe put a heavy line on so you can rig a "Bosun's seat to go up and down yourself for antenna work....Good luck, and have fun with your tower ;)
Reactions: Galaxy 959
Ooops....I meant, "Put a beam on it". A bean I don't think will Tx.")
Reactions: 2RT307
How much differnce locally.
As far as dx I have an IMAX 2000 on a 8" corner 5' fence post and worked well then again my property was 1060' above seas level too lol
A good tower will barely notice the Sirio is on top of it. I'd use the whole thing. Or buy/scrounge a pole for the gp and put a "bean" on the tower. ;) You'll be amazed at what a 3 or 4 element Yagi can do. Or a quad... and that's a whole other conversation. :)
73,
Brett
    535A has left the room.
  • @ AmericanEagle575:
