So if using LMR400UF and an 8" circular form and wrapping 18' to 21' around it be about right or at least sufficient not to be too small of too large of a bend for it as far as radius goes?
How'd you place to ferrites?
All technical data aside, one could use a commercially produced choke and be done with it.
I experimented around with air wound chokes, beads and baluns, and this worked the best with my mobile antenna controlling common mode currents. Of course the advertising is somewhat hyped up so don't believe everything you read.
Kind of expensive compared to what you can make yourself, but it is neat in appearance and gives your antenna system a uniform look.
DX Engineering Maxi-Core® Feedline Current Chokes
DX Engineering Feedline Current Chokes, using Maxi-Core® technology, prevent unwanted RFI by eliminating feedline current and radiation in 50 ohm, coaxially fed antenna systems. They provide excellent feedline decoupling and low loss performance from 1 to 60 MHz and are power rated for 2 kW continuous, 5 kW intermittent.
DX Engineering Feedline Current Chokes have significantly higher common mode impedance and a larger effective core area than similar line isolators, including conventional enameled wire or bead baluns. This results in higher power handling with lower loss, improved antenna bandwidth, and reduced RFI, and compensates for a less-than-optimal grounding system.
While the most common advice is to improve the station's RF ground, the root of the problem is in the poor isolation of the feedline from antenna currents. In other cases, as the coax feedline travels through the near-field of the antenna, the current can be reintroduced to the feedline after the balun. If your SWR is already low and you wish to reduce feedline radiation (RFI) and improve reception, DX Engineering Maxi-Core® Feedline Current Chokes are recommended.
