I recceived the cable today & made some adjustments on the Bearfoot lll amplifier, I turned the tune control & the load control & when I engaged the mcirophone to talk the watt meter showed about 80-85 watts.I'll be getting that short cable that I need too join the watt meter & the antenna tomorrow is what usps.com says online.
Will give you the results of the wattage soon.
I try to talk to my brother about 12-15 miles away & he could bearly here me once.
This Harlan county Ky. has mountains in it.
Tell me what you think, shouldn't this cb output go out farther than what I stated above ? Thank you
