Hi DB,
Don't worry, it's not the first time that its been pointed out to these people that using DX is not a good idea for testing antenna's.
I'm definitely not worried about it.
It has also been pointed out that not using the identical apparatus for each antenna test (same coax, same mounting pole, same rig, same pl plugs etc) is just testing a persons ability to solder a pl plug and the fact that no two locations can ever be the same because of attenuation.
Yep. The only possible exception I can think of here is if you know antenna a performs better on apparatus 1 and antenna b performs better on apparatus 2. Although the only way to know such a thing is previous testing with said antennas side by side.
For example, you mount two antennae one wavelength apart then run both coax into a switcher box and then into a radio. Firstly, besides both set ups having completely different apparatus, the angle of TX/RX to each breaker you use in testing is critical in as far as attenuation is concerned, even each respective antenna will attenuate the other depending on where breakers are.
But it seems like educating a bacon sandwich DB at times because they WILL NOT LISTEN.
MMMM, bacon... I much prefer eating bacon than trying to educate it.
There have always been and always will be people like that. I don't let them bother me. Let them believe and do what they want. Life is much easier that way.
The DB
