Best beam for low height
20-25 ft tall? A vertical beam would be a waste but a small flat beam would work fine and at least you'll be able to shoot skip.
Reactions: Marconi
Definite a moxon for light weight ease of install and small rotor to turn it.
I have looked up the moxon several times...question? Is it a dipole with a feedpoint on one side and dipole director on the other? Can I use a commercial dipole with a balun for the director?
the feed point is just like a dipole,, but the ends of the dipole are folded back 90 degrees,, then the reflector portion is just solid with no connection points,, here are a couple pics, one is of a vhf version but same concept just larger for hf, the other is a 10m version, here is a moxon calculator: http://w4.vp9kf.com/moxon_design.htm
    535A has left the room.
  • @ AmericanEagle575:
