Best current production true CB?
N
NorthStar34
Guest
This is a tough question. Best all around I think TexasRanger/Galaxy is hard to beat. But when it comes down to audio and power. Cobra is tough to beat. Uniden's are kinda inconsistent some will do the power and some won't.
</p>
I'm interested in hearing everyone's opinions on what the best, currently in production true CB on the market is and why. C'mon everyone, let's hear your opinions!
</p>
none anymore <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)">
I guess I would have to still go with the Uniden line..any of them better than cheap ones... 68's....7X's
73's, -=BattleAxe=-
</p>Edited by: <A HREF=http://p067.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=davemade32>DaveMade32</A> at: 7/26/04 4:57 pm
In my opinion, the Grant LT is the best CB radio ever made, that you can still find. I'll back up this statement in a moment. the Grant LT is the same as the origional cobra 148GTL, and the Grant XL. DON'T be fooled by the new Cobra 148 GTL, or the 148 NWST, they are a cheap copy that don't impliment the same circuitry as the origionals.
First of all, you cannot beat the receiver. The receiver is one of the best that was ever made in a CB radio. The IF stage is designed nicely, and filtering is adequate. they don't "jack" the gain up so high in the front end to make up for attenuation, and a very low Q later in the circuit like alot of the export chassis.
Secondly, the VCO design is great for a radio in it's class. It's pretty much rock solid, and very stable.
Third, board design, the board design eliminates by it's own design circulating current effect. This is an important thing when dealing wih RF higher than 3.5Mhz.
Fourth, it impliments the AN612 balance modulator, which is a good thing, in English for SSB use.
Fifth, with little effort, the MB3756 is aduquate for voltage switching/regulation which eliminates deviation from voltage fluctuation o the VCO / carrier oscillators.
Sixth, with a little improvement, the bis supply remains constant without going negative, which limits output power and increases distortion.
Seventh, after modification, you have direct AF coupling to the modulator. (current regulator) This is great for a wide bandwidth for audio frequency response on AM. The highs and lows aren't rolled off a sharply.
Eighth: Refer to #7, but the mic amplifier circuit is easy to modify with some capacitor changes to tailor the AF response to a user's voice.
IMO, just all around a great CB radio.
Take care Tim,
Justin
PS, I'm compiling the scans of the magmun information I have written up, and it will be on our site soon, just give me a couple more days.
<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)">
</p>
10-4 on the Grant LT.....but I was trying to get opinions on "Current Production" models.....
</p>
Yes as a last resort, the TR-296 will do just fine it's verrryyy (very stressed) similar to the grant/148gtl chassis.
</p>
Galaxy 959 is a tough cb to beat far as features and performance. This radio also has a good reciever.
</p>
That's true Northstar, it isn't bad, and the receiver is marginal, but it can be upgraded to a mosfet design or gasfet.
</p>
Cobra didn't allow anything, really, uniden manufactured their chassis for quite a while, after dynascan stopped making them. i'm sure it has something to do with keeping the cost down. But yes, I have several ways of making them stable.
</p>
Here's a couple of hints, looking at the radio, component side up, front of the radio facing you, look to the left, all the way to the left, now go down towards you (the faceplate) until you get to the PLL chip, look to the left of the PLL chip. You'll see a 10 ohm 1/8 watt resistor. By now, it's either discolored or blackened. This causes 90% of the failures in this radio, and the component is so hard to see, not alot of shops can fix it. Replace it with a 10 ohm 1/4 watt. Also, adding a 1000uf 16 volt electrolytic from the top of the diode (+ side) to circuit board ground, right in front of the voltage regulator (7809) gets rid of the SSB warbling. There are also about another 17 component changes you can do, but obviously I really don't want to post all of the engineering changes we have researched publically.
</p>
