Best way to attenuate input to a grid driven tetrode.
Naysayer
Solder Balls
I Support WorldwideDX.com!
Mar 6, 2020
265
204
53
New York
My FT891 only goes down to 5 watts and shuts off if I lower the VDC below 12v.
A series resistor sounds like trouble. How far can I reduce the 750 ohms 'swamping' resistance to ground without altering the input impedance a'la Pride formula? It would make tuning & trouble-shooting easier if I could limit output to a few hundred watts.
OK I have some reading to do.
I briefly saw that t match can also aid impedance matching.
Is it feasible to use the pride’s swamping resistance of 750R as one of the T-pad’s resistance values? It’s already there
About that 750 ohms. The input transformer has a three-to-one voltage step up, which gets us a nine-to-one impedance step up. Should translate to 450 ohms, not 750. I use four 470 ohm resistors, two series pairs in parallel. I'ts an overkill thing. Joe CBer may overdrive his Pride, but the new swamping resistors won't suffer. Other stuff will. Gets me the equivalent resistance of a single part that value. The factory's two original 1.5k 2-Watt resistors routinely overheat. Not sure what the designer was thinking with that 750 ohm value, except maybe to get a bit more drive to the tube grids than a proper 450 ohm swamping resistor value would do. Don't see just how that makes sense, since it's exquisitely easy to overdrive even with a swamping resistor closer to 450 ohms.
A T network does serve to bring the input match closer to 50 ohms in the DX300. The T attenuator will minimize any mismatch in the tube's grid circuit impedance. Whatever the input SWR was before, the T attenuator will tend to reduce it.
There's more than one way to skin a cat. We tried using a two-to-one input tranformer ratio with a 200 ohm swamping resistor in a Pride. Took too much drive power to achieve the signal voltage needed on the control grid. The T network with a three-to-one transformer provided a better "middle ground" appropriate to a customer's "two-final" black base radio.
I assumed that the 750R RF swamping resistance was reduced by the .01uF bypass cap so it's closer to 450.
I'm considering dividing one of the 1.5k resistors (the 2nd one after the trifilar on the way to band switch/tube grid) into 1.2k and 300. The 300 would be in series on the way to the grid but together with the 1.2k maintain the original 750R total resistance to RF ground from the trifilar. That way I get 300R attenuation in a pi form without disturbing the original circuit (750R total to RF ground). The 300R would bridge the 1.5k and 1.2k in a pi shape. The 300R resistor would be Non-Inductive.
  • @ Geoexplorer69:
  • @ Geoexplorer69:
