Does any one know any thing about a Big Daddy Beam? 5 elements vertical and horizontial. It 's 22feet long and 19 feet high and wide.
If you can get one ...you will love it I have had one up for ten years built like a tank .Does any one know any thing about a Big Daddy Beam? 5 elements vertical and horizontial. It 's 22feet long and 19 feet high and wide.
Do you know any one that wants one?If you can get one ...you will love it I have had one up for ten years built like a tank .
Mur
sIf you can get one ...you will love it I have had one up for ten years built like a tank .
Mur
Not a thing Marconi, like I said built like a tank has been through wind storms heavy snow loads with no boom support screws used through out the beam .Yes it could use support but I never have but it comes down every two years for a cleaning and inspection .s
Murdog, if you see anything I said wrong or questionable, please let me know. I would like the feed back for considering my model results for this antenna. I have some old pretty beat up parts from a beam antenna I took down long ago...that looks to have very similar parts, using swagging, bolts, and element saddles like Maco/Wilson use(d). I thought it was maybe an old Radio Shack or and old HyGain or a Wilson, but Wilson slotted and used hose clamps back in those days.
For example, did your antenna appear long and thus work lower than the specs suggested? How did the antenna hold up after 10years?
Did your antenna bow or did you have to support the boom?
