Thats the first one I looked at, then came across this one, difference was the " two-position Element Range extender circuit " this is very appealing to me.
I would not put more power through an element than it is rated for no matter the compensation rate.
Nope, it uses 9 volts as well. I set mine up to do x1, x2 and x4, I rarely use the multiplier, but it's definitely nice to have. It also has a built in calibration circuit using the 9 volt supply. I had issues with my PR-90 and sold it.I assume the other is converting rf power for it's power source for it's pep function.
That's plenty close for government work Beetle
