Boomer 250
Ziploc
Mar 19, 2016
299
136
53
52
Scored on a boomer 250. 1 watt from radio box on low dk 30 . On high dk 60. On what setting would I sound best? Thanks . Btw cheap meter Astatic pdc-1
Reactions: Tokin
I don't know if anyone actually scores when they get a Boomer but if you got a good deal and it's clean it is what it is.
The setting that sounds louder at the other end is the one you want to use.
A higher wattmeter reading doesn't tell you what they are hearing at the other end.
And if it sounds the same at 60, go for it. Shouldn't work the thing hard enough to cause trouble.
