Hello everyone new to this sight and cb radios so be patient im green lol but love this stuff. I have a few questions on my set up, I just bought and installed a cobra 29 ltd, brand new 18' wilson coax, brand new truck stop mount and brand new 4' firestick. Not to make this a long story but its the best way to describe my problems, Bolted my mount to tool box which is metal and bolted to the bed which has no rubber gaskets on the mounting bolts neither does the antenna mount so im guessing it should be ground. Next ran my coax to cb with no hard bends at all threw my fire box and to the radio which i bolted next to my 4x4 shifter i grounded the ground to the driver set mounting bolt and the power wire to the cig fuse in the fuse box. I get pretty good reception it reaches pretty far out but when i try and set the antenna with my swr meter it pegs out to the right past the cal arrow, I tried on channel 20 while switch set on CAL set the to the cal arrow held the key on the mik switched to swr and it pegs out right past the CAL arrow but if i switch to sf swr the very top option it drops to 3.0 which is to high but its better then on swr which pegs it out. So i no thats not right then i try 40 and 1 to try to set the antenna both those channels do the same thing swr both peg out sf swr both on 3.0. So then i tried running a ground from the antenna mount to the frame and still does it. The key up like barely shines bright and im getting to my wits ends please does anyone have any ideas for the worm lol. Here is a couple of pics of my antenna set up and is there supposed to be a ground wire? even though i ran one that still doesnt get it
