Well.. I decided to try my hand at building a vertical antenna for the house.
I was looking at designs on line and stumbled on this page: 6 Meter Repeater Antenna 1/2 Wave Coaxial Vertical Antenna Design
The current idea is:
102" Radio Shack whip for the stinger
3/8 x 24 Feed Through for the stinger mounting
1" x 10' copper for the inner coax run
1.5" x 10' copper for the outer lower half of the dipole
1" cap
1.5" cap
I plan on constructing it just like the website shows, running the coax (RG-8X up through the inner 1" pipe), but I have a question about scaling it for 11/10 meters...
I am thinking the the 1.5" lower/outer pipe makes the other half of the dipole, and should be cut to length (around 102") to match the 102" on the stinger.
I realize I am basically building a Shakespeare Big Stick, but building is a lot more entertaining than buying (cheaper too), and the copper will blend in nicely with the surrounding landscape...
My question is:
Is the length of the inner 1" pipe critical to the operation of the antenna?
If so, how long does it need to be while still allowing for mounting?
Thanks
1" cap
1.5" cap
My question is:
Thanks
