All the mount you'll ever need. Barjan - Product CatalogFor a wilson trucker5000 mounting on mirror for a bigtruck.
If you knew anything about this mount you'd not say that about it, I ran one with a 12'' shaft predator 10-k for 5 years without a problem and the mount in question also has a place to use 2 wrenches and the one you're talking about will hold a wilson 5 k which by the way is also made by (BARJAN) so what better mount to use that one which is made by the antenna manufacturer?Stay away from Bar-Jan. Go to your local CB shop or a Flyin J or T/A truck stop and buy the Firestick Stud ( has 2 places to put your wrench on it. ) Better Quality and last longer. JMHO I always changed the studs once a year and take a little bit of fine sandpaper and clean the top of the mirror bracket off where the stud goes up through. In my case i use a vise grips plyers i slip seat for the company i drive for.
Yes it will work perfectly fine, my suggestion is just to give you the best stud for your money and still work later on if you choose to get an antenna later with more wind load.I have a Francis stainless stud do you think that would work?Im not useing that 5" shaft version so I wouldn't think there would be too much stress on the mount although coming from a 2000 its definately heavier.
The mount you're talking about is uses a 5/8 wrench to tighten and the one I suggested uses a 1 1/8'' wrench on top and a 13/16'' wrench on the bottom so that being said the mount I suggested has a much larger footprint therefore making it much more stable than the mount you're suggesting.
Mack i wont say no more. Ive been driving trucks for 33 yrs now but from now on i will keep my comments to my self. BTW that Firestick stud is a lot better than that Bar-Jan.
