cap & resistor mod
Number15 said:
Has anyone done a cap and resistor mod on a galaxy 99v if so were do i put the cap. I have done this on 29s Thanks. Number15.
Do the NPC or PPE mod.
Galaxy radio already has variable power so the resistor would be pointless.
#15 , you can look in the mod section of the Forum , and you will find what you need there. Good luck to you.
  • @ Geoexplorer69:
  • @ Geoexplorer69:
