Now you have me thinking about installing a fan speed switch, at least three speeds. Is there a formula that will help tell what wattage resistors you'd need to have a fan that normally runs at 14 volts to have a high setting that runs at 14 volts, a medium setting at 10 volts and a low setting at 5 volts? Then again, this is the exact type of thing that may end up with me having to send the amp back to Carl Built for repairs caused by an owner that just could not leave the damn thing alone. Well, stuff breaks when I am learning. When I was a teenager I learned the really, really hard way about the importance of paying close attention to timing chain mark positions in an interference engine. But it also ended up giving me a great project engine to tear down and remove/repair the bent pushrods, a few broken valves and pistons, and related machine work.
