To get an understanding of what is required to change a 10 Meter antenna to an 11 Meter antenna use some math: This can explain a lot.
Basic formula: 468/F(MHz) is used to calculate the driven element (i.e., the element that is connected to the coax). The 468 formula is the standard ½ wave dipole formula. For 10 Meters one is likely to use 28.400 MHz for the design frequency (used for the lower part of the band for CW and SSB phone operation). For CB (11 Meters) the likely design frequency is 27.185 MHz (Channel 19 about in the middle of the band). Thus for 10 Meters the driven element is calculated as 468/28.400 = 16.478 ft = 16 ft, 5.75 in. For the CB band the driven element is 468/27.185 = 17.215 ft. = 17 ft, 2.6 in. You will need to lengthen the Driven Element 0.737 ft, or about 8.8”. That’s about 4.4” on each half of the dipole.
The Reflector Element is usually 5% longer than the Driven Element, so it should be about 17.215 x 1.05 = 18.075 ft = 18 ft, 1 in.
The first Director Element is about 5% shorter than the Driven Element or 17.215 x 0.95 = 16.354 ft = 16 ft, 4.25 in. The other directors are about 5% shorter than the previous director and so on.
So you can see that the antenna needs to be lengthened in general since the CB band has a longer wavelength than the 10 Meter band.
For the purist, the spacing, or distance between elements should be greater to maintain the same gain specs. However by leaving the spacing for the 10 Meter band the gain will decrease a small amount, so small that it isn’t worth the trouble.
Here is another site that explains yagi antenna designs, and provides further understanding.
http://signalengineering.com/ultimate/yagi.html
I hope this helps you some.
Mike
Mike and henryctx, I'm not sure which beam model Henry has, but HyGain made several 10/11 meter models. My model is th LJ-105CA, 5 element, 10 meter Long John and is said to be setup and specifically tuned for all modes from 28.200 to 29.500 mhz with bandwidths ranging from 400 to 1100 khz for different modes. This should suggest that this antenna is very sensitive to individual settings within the very broad 10 meter band.
The problem with using the math or a calculator is...those procedures never consider the variables in the material length, per tapered element. You may end up close maybe, but such variables in material diameter do create errors that only modeling and then testing can calculate correctly.
Of course such errors can surely be adjusted-out to match and resonance during the tuning process...if you have the patience to do the work, and since you may have to tune the feed point trying to get a match on a modified multi-element antenna, you will have your work cut out for you, and you have no real guide lines on the resonance for all 5 elements. It will be like working from scratch.
Here is what Telex told me some years ago when I asked a similar question about the model I have.
View attachment HyGain LJ-105CA.pdf
The problem with this beam can develop due to not having enough tubing material for the tip elements and then trying to successfully modify all the settings. My beam came with an adjustable beta matching device, but several of the other 5 element beams HyGain made for 10/11 meters came with fixed beta matching devices, so they were not intended to be tunable at the match.
BTW, I was never able to get my beam to work as I expected in the CB band, and I used longer end tubing to reach resonance. The match was OK, but the performance was less that the preformance on my homemade 4 element horizontal yagi.
