I was wondering if it were possible to put a beam antenna on a mast. I was looking at the L2 Quad from Lightning Antennas.
http://www.lightningantennas.com/quad-models/l2-quad-bis/
I have read and heard that masts should not be used with beam antennas but this beam is a small 2 element beam weighing 11 lbs with a wind area of 1.8 square feet. I was hoping this may be small enough to use with a mast. I understand that i would have to use guy wires and was thinking a Rohn 50 mast would be suitable. I would also have to use a small tv rotor to move this around.
Has anyone had a set up like this before? is it possible?
