I decided to start a CB go box project. I would like a unit i could take camping away from my mobile but be able to make some contacts have some fun in the field. I know Go box's are big with the Ham community but i haven't really seen much as far as someone doing it with a CB radio. I have an extra Uniden 980SSB that i was planning on using for the radio as well as an extra RM KL203P amplifer that i was going to use with it as well.
I am planning on using LiFePo4 batteries but I am running into math problems when trying to figure out how much battery i will need. I wont be constantly transmitting but would like to be able to get like 12 hours of regular usage time. Any thoughts on this would be great. The uniden drains 2.2 amps on am and 4 on ssb
the KL203P drain shows 10amps power input per their individual manuals.
From there i am planning on putting a solar panel hook up to it for recharge/running power. I would suspect i need a charge controller as well as a distribution block for the power going from the battery to the equipment.
Other things i have thought about adding into the box:
SWR meter
Cooling Fan
Speaker
I posted questions on the antenna side forum and have concluded i will most likely be using a portable dipole antenna for this project
Any and all suggestions and comments are welcome. I would like to get input from people here while i build this project and continue to update with pics as i go to see what this may evolve into.
Thanks
SWR meter
Cooling Fan
Speaker
Thanks
