CB radio, base and mobile antennas, 10 meter linear amp
Turbo T
Certified CB Rambo
Feb 2, 2011
963
142
53
I'm selling off my CB radio gear. All of my gear works great, nothing wrong with it. I'm just getting out of CB's and moving on.
Midland 77-155 40 channel CB radio. This is a 12 VDC mobile radio. Has mic gain, instant ch. 9, hi/low speaker tone, PA and it even has a distant/local switch--this really comes in handy when you don't care to hear everyone on skip and just want to hear the guy a few miles up the road. The radio also comes with a power cord, a mouting bracket and a Diesel 360-B dynamic mic. The radio works excellent. The metal case is scratched up, nothing some spray paint couldn't fix. $20 shipped in the lower 48.
Maco 2 pill linear amplifier. This is a 12 VDC mobile amp. Comes with a 6 ft. home made wiring harness consisting of two 12 gauge power wires, one red and the other black. A relay is inline on this harness to switch the radio on and off. also has a 3 pin pigtail on the relay to fit Cobra, Uniden, Midland radios. The amp works great, no issues at all. $110 shipped in the lower 48.
** I will sell the Maco Mite II and Midland 77-155 together as a package deal for $115 shipped in the lower 48. **
Shakespeare big stick base antenna. This is a 1/2 wave fiberglass antenna. It is 18 ft tall and is made up of a 10 ft and an 8 ft piece. Will talk 25 + miles on a stock 4 watt radio when the base is 15-20 feet off the ground. $30 you pick up.
102 steel whip antenna, with adjustable antenna base, barrel spring and threaded rod extension. This is a mobile antenna. In good shape. $15 you pick up
Brand new 102 steel whip antenna with adjustable antenna base and brand new barrel spring. This is a mobile antenna. In excellent shape. $25 you pick up.
I'm located in Johnson county, Missouri.
Here's a few more pics of the amp on the inside...
Also when I paired this amp with the Midland 77-155 with a 2 watt deadkey, on my meter it was showing over 50 watts of deadkey and over 200 watts of swing.
