The Retevis Holidays giveaway winner has been selected! Check Here to see who won!
Does the problem go away when you disconnect the antenna? If it does, then the power wire filter choke probably won't do any good. If the noise remains when the antenna is disconnected, then I'd try the filter. Might work.
Need help lost my channel chart . Cobra 148 GTL with a 8719 and 11,1125 crystal 26.175 to 28.045 , Need the chart I can fill in the blanks slide 2ck up and 12 kc down
