Cherokee CM-10 volume control POT
Jan 18, 2009
60
I have Cherokee CM-10 that I only got to use once and the volume control started to cut out.
I use to be able to wiggle it and it would work but no more. I need to fine a new POT to replace it with.
anyone know where I can get one?
Did you try spraying some contact cleaner into the volume pot first? That might do it. Other than that, I'm not sure where you'll find the POT by looking for that radio. You'll probably need to remove the POT and find one like it. It's probably a common part. If you have a multimeter, you should be able to measure its minimum and max resistance and find one just like it fairly easy.
Hope that helps.
