Chimney is 2 years old and is for gas furnace goes from ground to about 8 foot over roof and is 22" squared. Using 3 chimney mount straps how long of a mast should be used to hold a Mack 5/8 ground plane? If fence pole was mounted from the ground along the side of chimney and attached every 4' up could I go higher? Never mounted to a chimney before but due to trees its the best spot for my friends antenna.
