circuit torn
I'm not really sure of what you're saying. If you mean the circuit traces, the copper foil strips, came loose from the circuit board, then you have a couple of alternatives. Just depends on how badly those traces are 'torn'. If you can delicately make the traces lay flat, solder them together, you can then just sort of 'glue' them back to the circuit board. Fingernail polish works. If they can't be soldered back, then use some small wire as a substitute for those traces. Make good solder connections where the trace starts to lift from the board and follow it's path to where ever it goes (and is still lifted from the board). If the 'tear' or break is small, a drop of solder between the two lifted ends works sometimes.
If that's not what you were saying, needless to say I have no idea how to repair it. Good luck.
    GlocknSpiel has left the room.
  • @ kingmudduck:
    So I have a cobra 138xlr and the meter dose not work... It dose not key up and signal dose not work.... It is not stuck it the meter moves freely. now wires are resoldered on both ends...So now that do I look at. Could it be a diode or a transistor?
    Greg T has joined the room.
    Greg T has left the room.
