Decided to install dual antennas.
What is the best/easiest way to tune. Read several different methods.
Method 1
Set SWR using 50ohm coax from radio all the way to 1 antenna. Tune to SWR of 1:1. Then adjust 2nd antenna the same way. Then install the Co-phase 75ohm coax to antennas.
Method 2
From radio to antennas with co-phase coax. Then adjust both antennas at the same time.
Method 3
From radio to antennas with co-phase coax. Disconnect 1 antenna and connect a dummy load to that side. Then adjust the antenna on the other side of the coax. Then remove dummy load, connect that antenna, then adjust that antenna.
Have 2 SWR meters. One is an Astatic PDC2, the other is a Workman HP202S dual needles. The Workman paperwork says it doesn't handle 75ohm coax very well. So will have to see how that goes.
Another weird question could I hook it this way. Radio, 3' 50ohm coax, PDC2, 3' 50ohm coax, HP202S, coax to antennas/tunning method?
Using Uniden 510XL to set SWR, then installing a Connex. Will I have to reset SWR after radio swap?
Method 1
Method 2
Method 3
